Best Consumer unit for home | on ElectriciansForums
Discuss Best Consumer unit for home in the UK Electrical Forum area at ElectriciansForums.net
James
Staff member
Mentor
Supporter
Patron
Solutions
midlands
I try to keep out of Domestic work but I have a problem at home.
Currently I have a wylex fuse board with re-wire fuses.
they are great because nuisance tripping never happens!!
however, it is an overhead TT supply and this is covered by a 30mA non delay rcd that covers the whole house.
this evening the rcd tripped and the wife got mad at me.
because in her mind being married to an electrician means that our electricity should be of a better quality than everybody else's and one stupid trip switch shouldn't turn everything off.
now no amount of waffle and bull faeces including flux capacitor integration into a 100 year old house is going to persuade her that it cant be done so I am now sadly looking into doing a job that is 10 years overdue.
If I am going to do it, I am going to do it properly so what are your recommendations for domestic consumer units?
may as well have all the mod cons in it SPD, RCBO, time delay rcd incomer.
are there any other bells, whistles or collections of random letters i should be thinking about?
might need a pen fault detector as i think in future they may upgrade the supply and i have a car charger.
Depends.... Do a GOOD EICR first and see if the wiring will cause a RCBO board issues ... if so, stick on a twin RCD and hope for the best or do a full rewire .God know how many "stolen " neutrals and earth etc you have?
I have no continuity between N and E
global IR is good
I have already decided to replace it, any issues found when doing so will be rectified.
so really i am looking to find what the best gear is.
my normal go to for industrial is eaton but i think maybe Schneider might have a better reputation for domestic?
And before anybody tells me that i should get a registered electrician to come round and do it,
or the specification of something like this is to complex to suggest online because we think that you are about to take on a DIY project above your knowledge base.
Trust me when I tell you that i have changed several sockets and lights etc in the past and they all work fine so you have nothing to worry about ;-)
I've been using Contactum, I think they are the Defenders, for a while and I've had no issues. They have nice space inside, look nice. Last one was in the summer replacing a couple of ancient Wylex 3036 boards. Plenty of device choice, if you need things like timers and such like.
I've only fitted one Schneider, Easy series, but I've worked on a few and there's just something that I can't quite put my finger on... I tried it, didn't like it and never did another one.
If it was my own house I'd go with something that guaranteed future availability for upgrades etc.
Hager or Crabtree would tick this box, along with being decent quality, but starbreaker would be top of the list - DP RCBOs ensuring no stray neutral currents give rise to angry wife and plug in busbar means no chance of having to switch the lot off if adding another circuit.
Edit: What @westward10 managed to post without the sales pitch.
ah, ok the starbreaker boards are not the same as the board i have in the workshop, that uses a more standard busbar type distribution.
My own house would be the old plastic MK board I have collecting dust in the garage and use up all and any old RCBOs I have kicking about from other jobs that I can shoe horn onto the busbar
because in her mind being married to an electrician means that our electricity should be of a better quality than everybody else's and one stupid trip switch shouldn't turn everything off...
I feel a bit silly now, not having thought of that suggestion.
As mentioned by nicebutdim, if I was planning to live there long-term, I'd want something that will be supported long-term. So much though I like and routinely install Fusebox, I'd have to wonder will they be around in 10 or 20 years, or would I end up looking on eBay for spares. It is hard to know for sure of the decent brands which will survive long-term, my best guess is Hager.
Schneider acti9 3 phase is great but I'm not keen on the easy9 domestic single phase. Fusebox seems ok but it's Hager for me.
For donkeys years, I was a Wylex fan but not the latest stuff.
Reply to Best Consumer unit for home in the UK Electrical Forum area at ElectriciansForums.net
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
I opened up the CU again and the round junction box above and what I found was the blue and brown wires coming in from the wall just above the 15a...
2 3
