Best type of lighting in stables | Page 2 | on ElectriciansForums
Discuss Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Cumbria
I have built a stable block consisting of two stables and a store. I have applied to have mains electricity installed, and as part p won't apply Iwill be wiring them myself. My question is do led strip lights have as much shadow as led floods. I have been using 12 volt floods, which are great but do cast shadows. I was thinking of fitting weather proof led strip lights, hoping they would be similar to the florescent strip lights. Any ideas?
Ah right - your OP says 'you will be wiring them yourself' so I assumed the new wiring would need testing. No worries.
Sorry should be clearer. Most of wiring done, tested as I go along, but mains not connected yet, and no light fittings on yet. Will be finishing wiring over next couple of days, mains due to be connected Monday. As it is a stable does not need certificate or testing by 17th edition registered sparks.
I'm with you. Not sure about this bit though - all wiring systems should be tested on completion.
Getting a bit off subject, but it's not a dwelling, it's a stable, BS7671 only applies to dwellings.
[ElectriciansForums.net] Best type of lighting in stables
Reply to Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Leaking means measure from ground of frame to AC ground. There is no capacitor and no resistor. Its dangerous to have such high leakage. YES...
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
