Best type of lighting in stables | Page 3 | on ElectriciansForums
Discuss Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Cumbria
I have built a stable block consisting of two stables and a store. I have applied to have mains electricity installed, and as part p won't apply Iwill be wiring them myself. My question is do led strip lights have as much shadow as led floods. I have been using 12 volt floods, which are great but do cast shadows. I was thinking of fitting weather proof led strip lights, hoping they would be similar to the florescent strip lights. Any ideas?
Oh dear, seems like a little bit of knowledge and all that. The stable is in a field. No house on the land. No one lives in the stable, people that is, and it is not regularly occupied. It is therefore not a dwelling. BS7671 applies to dwellings, it says so clearly. If you think I am wrong, I will give you the name and address of my local council building control officer and you can correct him, as he confirmed the fact that BS7671 does not apply, and test and certificate was not required.
A little knowledge and all that indeed ....... but not on the side of the forum.
Here are the specific exclusions to BS7671 listed in Part 1. Can you see stables in it ?
[ElectriciansForums.net] Best type of lighting in stables
Static Zap, read my posts, the installation WILL be tested. I qualified as an electrician in 1965! Haha, still qualified enough to know how to test an installation, 50 years in the trade altogether, with local dno.
More to the point, can you show me where a building that is not a dwelling is covered? Unless it tells me that a non-dwelling is covered I couldn't give a hoot.
BS7671 applies to all electrical installations subject to the exceptions given by any78
have a read of section 705. i believe horses come under the general scope of livestock, even if i prefer them in a plate with chips, mushrooms and a touch of garlic.
Only applies to buildings covered by the regs, such as agricultural buildings that house livestock. I'll go with the planning officer, suits me. My animals are safe, probably safer than if the wiring was done by some of the registered sparks whose work I've seen.
stables come under the broader classification of agriculural and horticultural. just because the BS does not specifically mention stables per se.
polo mints are not advertised as containing a nitrogen/oxygen mixture, but we all know there's a hole in the middle, same as with your thinking.
Reply to Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Leaking means measure from ground of frame to AC ground. There is no capacitor and no resistor. Its dangerous to have such high leakage. YES...
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
