Best type of lighting in stables | Page 6 | on ElectriciansForums
Discuss Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Cumbria
I have built a stable block consisting of two stables and a store. I have applied to have mains electricity installed, and as part p won't apply Iwill be wiring them myself. My question is do led strip lights have as much shadow as led floods. I have been using 12 volt floods, which are great but do cast shadows. I was thinking of fitting weather proof led strip lights, hoping they would be similar to the florescent strip lights. Any ideas?
If you are an electrician of 50 years,like quite a few of us on here, your view that testing an installation is not required ( because only nags kip there)
It is not only unique,it is silly
I think your views need to mature in order to match your likely age
Dno have already made connection, just waiting for supplier to fit meter. Look, if stables aren't mentioned as being covered, and horses are defined as not being livestock, the building control say I can wire it without it being covered by part p and the 17th edition, then yes, I will go with it. Why should I pay a lot of money Isn't need to?
Best you get that clarified in writing .......... are you expecting any form of sign off by LABC?
Being as this thread is now getting ridiculous I am going to take it off topic by reciting a little incident that happened to me while walking the dog. This very well to-do lady in a big 4 x 4 and tweed jacket stopped and leaned out the window and said, "excuse me, could tell me where osshow is?" "Sorry" says I, where? "osshow" she says, then repeats "y'know, osshow". "I'm sorry luv, I don't think there is anywhere round here called osshow" "No, osshow, she says, osshow!"
"Oh, I replied, you mean the Horse show?"
"Yes, osshow! What did you think I meant??"
Derbyshire folk eh......
What brand of test equipment are you using.
[ElectriciansForums.net] Best type of lighting in stables
It will be installed and tested to the latest regs. If you accept thet BS7671 isn't a legal requirement on it's own, but is accepted as the required standard for the building regulations part P, then if the Building Regs don't require it for a particular building then surely BS7671 doesn't apply. If you look at the Building Regs
The Building Regulations 2010
You are here:
· 2010 No. 2214
· SCHEDULE 2
· CLASS 3
Exemptions from building regulations
The building regulations part p states that buildings in Class 2 (Buildings not frequented by people) and Class 3 (Agricultural buildings) are exempt from part p.
1. Subject to paragraph 2, a detached building—
(a)into which people do not normally go; or
2. A building used, subject to paragraph 3, for agriculture, or a building principally for the keeping of animals, provided in each case that—
(a)no part of the building is used as a dwelling;
A stable is for the housing of animals, it is not a dwelling.
Also definition of livestock and agriculture
The Agriculture (Miscellaneous Provisions) Act 1968 (1968 Ch 34)
The definition of livestock given in Section 8(1) of the Act applies to animals being kept for the production of food, wool, skin or fur on agricultural land.
Agricultural land is defined in Section 8(1) as land used for the purpose of an agricultural trade or business
Also if you read the Building Regulations Part P, Section 2, 'Scope' 2.2
says what buildings are exempt.
From IET:
Q3: To what types of electrical work does Part P apply?
  • In or attached to a dwelling
  • In the common parts of buildings serving one or more dwellings, but excluding power supplies to lifts
  • In a building that receives its electricity from a source located within or shared with a dwelling, and
  • In a garden or in or on land associate with a building where the electricity supply is from a source located within or shared with a dwelling
The term dwelling includes houses, maisonettes and flats. It also applies to electrical installations in business premises that share an electricity supply with dwellings, such as shops and public houses with a flat above.
The common parts of buildings includes access areas in blocks of flats such as hallways and shared amenities in blocks of flats such as laundries and gymnasiums.
Part P applies to electrical installations located in outbuildings such as detached garages, sheds and greenhouses.
Part P applies to parts of electrical installations located on land around dwellings such as garden lighting.
I rest my case.
You are here:
· 2010 No. 2214
· SCHEDULE 2
· CLASS 3
From IET:
I rest my case.
Best you review your sources ........... as I think you'll conclude that all wiring in the UK except as listed earlier in this thread should be installed to BS 7671
Part P and BS 7671 are 2 completely different things
You're not a spark are you?
Again you are confusing part P and the wiring regs. The wiring regs apply to all installs, whether farming, domestic, commercial, etc.
You have already admitted that your initial argument about it only applying to residences was wrong. You are digging yourself deeper the more you rabbit on.
Exactly. Part p is a legal requirement, bs7671 isn't. Part p doesn't cover the building concerned. End of story. But at the end of the day it is safe, installed and tested by an electrician.
So your argument now is that it's because BS7671 isn't a legal requirement. You are presumably then saying that it isn't a requirement for domestic installs as well? Either you are just trolling for an argument or you really have misunderstood the system.
Every wiring installation needs testing and certifying, it may or may not however need notifying to building control as part of the building regs.
Reply to Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Leaking means measure from ground of frame to AC ground. There is no capacitor and no resistor. Its dangerous to have such high leakage. YES...
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
