Best type of lighting in stables | Page 8 | on ElectriciansForums
Discuss Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Cumbria
I have built a stable block consisting of two stables and a store. I have applied to have mains electricity installed, and as part p won't apply Iwill be wiring them myself. My question is do led strip lights have as much shadow as led floods. I have been using 12 volt floods, which are great but do cast shadows. I was thinking of fitting weather proof led strip lights, hoping they would be similar to the florescent strip lights. Any ideas?
...Right then...In the true sense of the rules,he is correct,but in the same manner,Hitler was a serious socialist and never got a mention in Brighton,this week ;)
I will not be quoting regs,or crabbing the OP's methodology,as we have not seen the installation,which could well be exemplary.
This is a similar situation,to the MOT exemptions for certain HGV's,which applied regarding street lighting,road marking,etc.
They did not need one,but gradually,the insurers requirement for record of maintenance,made it tricky not to use the MOT process,as proof of such.
I do a great deal of work,and have a great many friends,with equestrian yards,and here is a story...
One such fellow,lost three horses,in a night,due to series of common issues,occurring in a stable block,comprising of decent,well installed equipment.
Just 10mA is all they need...even the biggest Shire.
The investigation,and insurance claim,started a chain of events,which would have been not nearly as onerous,had the standard set of installation procedures,been voluntarily adhered to.
In fact,he was informed by the loss adjuster,the investigation,not just by themselves,but most of the other bodies,would have been "hugely restricted,if there was any paperwork regarding the block,to wave in front of people..." and that is a direct quote.
It's horses for courses...
Some one has asked about the installation. Mains is in a brick built cubicle at the back of the stable block, which is 2 stables each 12 foot square and 10 foot high. The store is the same size. This is totally inaccessible to the horses. There is a two way consumer unit (ip65) with a 30ma rcd main switch, fed with 16mm tails. Earth is to a 6 foot earth rod. Wiring is in plastic conduit, two circuits. One 1.5 mm for lighting and 1 2.5mm for a socket. A seperate 2.5mm earth is run for each circuit. All switches and the socket are in the store. Again this cannot be accessed by the horses. All switches and the socket are to ip66. The light fittings are weatherproof led battens to ip65, and are mounted at the wall/roof join. Non of it would be accessible by the horses. The socket also has a built in rcd. I cannot see much wrong with that installation. Non of the wiring is outside. Anyway, we will see on Monday whether the supplier will meter and connect it.
I still maintain that I have not broken any laws or installed a dangerous system. The EWR do not apply, I am a competent person, as required by the regs, it does not say you have to be registered. I know part P does not apply, and is a different thing, but at the end of the day, how many people have been taken to court for not complying with the 17th edition unless it is a complete bodge. I bet very few.
Before anyone says I should have used steel conduit, I feel plastic is more suitable, it will not rust and provides sufficient mechanical protection. Yes I know about rodents, but that is a lesser problem.
I suppose Devonchris gave some good advice. The highway code is not a legal requirement, but you can end up in court if you don't comply. So what he is saying I suppose is that as most people use a phone, drink coffee, eat a sandwich or exceed the speed limit ie ignore the rules then that is ok, so I can likewise adjust the 17th edition as suits. I hasten to add that is not what I have done. I really can't see why you have all got so upset. Anyway, I'll let you all know what happens Monday. Have a good day.
Personally i do them in swa, but sounds okay to me, people got grumpy because of the way your attitude came accross in your early posts, i understand its difficult to convey emotion by text but you sounded an arse haha, anyway hope it all goes well.
appreciate that you have most likely done a good job, but can't understand why you don't want to complete an Installation Certificate.You would then have a written record and proof that the installation was safe. if, God forbid, there was a fire or injury at any time, it's the first thing your insurer would want to see.
Well, I could issue a certificate to myself I suppose.
that's what we would all do. you can't very well have a horse in the client's details.
Right, now this your most sensible post in the thread. This is exactly what you should do. Wire it to the regs (I've no doubt you have wired it very well), test it, fill in the appropriate installation cert. You are then covered in the event of any future occurences and saved from any awkward questions from insurance companies
That's not what I said.
What ever Regs apply or do not, you owe a "duty of care" to anybody who may be visiting you property, ie Vets, Farrier or delivery drivers etc.
This link may be of interest to you?
Unlawful death by electrocution,caused by negligent electrical testing. - https://electrical-testing-safety.co.uk/why-we-test/unlawful-death
No one is in any doubt about your level of competence or understanding of the Regulations. You have demonstrated that in your earlier replies.
(Read in to that what you will, your good at that)
BS7671 isn’t statutory however E@WR are statutory and states quite clearly that all requirements of BS7671 are adhered to. So in actual reality this then makes BS7671 law, albeit indirectly
If not for that then your attempt to manipulate the rules to suit yourself would probably have worked.
For the sake of printing off a few pages and taking the time to enter the results you will get from the testing you say you will do. It might add 30 minutes to your time to fill in the forms with the results. Hardly worthwhile trying to interpret the regs differently to save 30 mins or less.
Reply to Best type of lighting in stables in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Leaking means measure from ground of frame to AC ground. There is no capacitor and no resistor. Its dangerous to have such high leakage. YES...
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
