I would vouch for Makita gear any time, bought a DHR242 about 5 year ago great tool to add to the existing cordless drills which are 8 to 9 year old now and going strong, wee cordless grinder Makita DGA452Z 18 V is one of the handiest tools I have (probably the most dangerous also to be fair). Took a chance and got an extra 2 x 3.0 Ah replacement batteries off amazon for round £25 (not real Makita they are +£) back in 2016 and can only tell the difference between batteries cause i engraved the date.
As an Amazon Associate we earn from qualifying purchases.
Sounds good mate hopefully mine last me that long!
I have two SDS drills one I inherited hidden in the barn when I bought the property and the other a Hitachi I bought because the other was so heavy, the one I inherited is a Triton, I know, I know, but it goes through anything, the Hitachi is no where near as powerful for heavy duty use, so when comparing SDS drills look at the hammer power for heavy use, the Triton has been going for the last eleven years, but not excessive use.
I have a Makita 6096D drill which is brilliant for light work as it is so light (1.3kg) and easy to use, only issue is now (10 years+ on) the two battery packs are tired and hold limited charge.
My SDS drill is also old (around 2006) and its an AEG 230V model and proven to be a good buy for the odd times I have needed it. I simply don't make enough use to justify getting a cordless replacement but interesting to see the discussion above.
That's pretty much a museum piece now.
Jokling aside, small cordless tools have developed at an incredible pace. The difference between 9.6V tools from a decade or more ago and modern 10.8/12V tools is almost as stark as the difference between bit and brace and a modern core drill.
only makita i have is a 110V SDS. comes out when there's a lot to do. last year, on one job, did over 100 32mm holes in 4" joists using a SDS auger bit on it. no cordless could come close.
There's no doubt that corded tools are well suited to certain tasks, but quite a few cordless drills would manage that task on a single charge.
Some manufacturers favour a dual battery approach for such drills, but others are manufacturing batteries with staggering capacity and output. Makita use the former and their batteries top out at 6Ah, but Milwaukee and Dewalt use single (large) batteries that now provide up to 12Ah for 18/20V tools. The Dewalt battery is part of their FlexVolt system, powering tools that operate at different voltages.
It has all become a bit overwhelming, not to mention expensive, which is part of the reason why I've stuck with Makita's easy to understand tools for simple people.
The reasoning behind dual batteries was the imposing by airlines on the battery voltage you could take on board, the manufacturers got over this by introducing the dual battery.
a modern cordless might be cometitive, but almost 3 x the weight to hold up. my 110V weighs in at under 4lb. a decent cordless battery weighs more.
There's also the fact that it's easier to sell tools if they all use they same batteries, which might explain why not all manufacturers have gone down the twin battery route. It's very likely that manufacturers find it easier to sell tools when they all use the same batteries.
Definitely and that remains the single greatest advantage of corded tools - at least it is in locations where power is available.
soon get power to anywhere with these guys.
scroll to 1.20.
Norwich
United Kingdom
Trainee Electrician
Best website for Makita tools??
Electrical Tools and Products
mrsparky,
Mike Johnson,
