if battery i'd look at hitatchi/hikoku.
thanks ill check it outWhat ever battery type make sure its Lithium Iron, Always found FFX to be the best value, at times have special offers on and undercut everyone for value: FFX | Home - https://www.ffx.co.uk/?gclid=CjwKCAjwxuuCBhATEiwAIIIz0Vu1jEfTnTtUG0Ho-_gR5vOXEhxL5eO-BvvGbxB-hEiEDY5-9ZTDJBoCdH8QAvD_BwE
hi mate, haha not a millionaire yet, ill defo have a look around thanks for the advice.OP is an apprentice - no mention of also being a millionaire ?
No matter what brand you choose, there isn't one best supplier and it's worth taking time to research as someone always has a better offer price on each tool. Most online suppliers will have free or a fixed nominal delivery charge, which means that there is little to gain in buying everything from one place.
If Makita is what you want, make sure to register everything online with Makita UK within 30 days of purchase as this will extend warranty to 3 years (excluding batteries, obviously).
The problem with a battery SDS they are heavy, especially if using them up a ladder, although they get rid of the cable they are an encumbrance in their weight and handling, think carefully before making a decision, perhaps even try one if you can.
I use them a lot at work but have never really had to use one at any height except on a pair of steps but it would just mean I wouldn't have to be borrowing the drill off of the electrician im working withThe problem with a battery SDS they are heavy, especially if using them up a ladder, although they get rid of the cable they are an encumbrance in their weight and handling, think carefully before making a decision, perhaps even try one if you can.
Brilliant mate I think thats the one I was looking at! hahaIn short, unless you want to start out with several versions of a tools that all do the same job, then middle of the road is probably the best option (something like Makita DHR242). While cordless tools are still generally heavier than their corded counterparts, the difference is not great and (for most jobs) the convenience far outweighs any additional weight.
If a little extra weight is a big problem, it's often easier to eat a few more weetabix than find a convenient source of power.
Model numbers is the 2nd trick to buying one, you want at least 5Ah battery and spare 5 aswell if you acting the machine with no plug top
Hi mate, ive already got 2 5ah batteries in my impact and combi but defo will get a third with the new drill!
Reply to the thread, titled "Best website for Makita tools??" which is posted in Electrical Tools and Products on Electricians Forums.
