Bizarre Wiring And Readings Through Upstairs Windows | Page 2 | on ElectriciansForums
Discuss Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
G
Gemma
Hi
I don't know if anyone can help, but I'm very grateful to anyone who can provide input. I won't go into the full story, but my windows upstairs appear to have an electrical current running through them.
It's only the windows upstairs.
They also set off a radio frequency detector.
Even if the fuse box is powered off, they still give an electrical reading.
It is not a home security system. Just bog standard double glazing.
The house was re-wired (not by me) and the electrician I had over recently noted what a mess it was and the upstairs and downstairs aren't on seperate circuits.
I have a photo, but I can't attatch it. It shows the window handle giving off a 12v reading, the same as my power points.
I also have a video of the windows setting off the radio frequency detector.
My friend, a glazer, came over and used a thermal imaging camera and we noticed the windows had unusual hot spots on the frames.
I have a feeling it may be being used for some kind of surveillance system that I am unaware of.
Very weird question I know, but any advice is greatly appreciated.
why not? upvc is the creation of the devil, along with weetabix floors, dot & dab, and roof trusses. who's to say that the devil has not introduced a phantom voltage to scare god-fearing peasants.
I found phantoms attempting to escape with one of those
(ÂŁLand) sticks from a cable hiding in plaster !
had that cable been to A&E?
In two minds whether this is a wind up or real, but I'm gonna bite.
What happened that made you aware of voltage on your window frame.
Why are you desperate
Why do you imagine there is some kind of surveillance on you
You say windows up stairs how many, or is it just one
What prompted you to use radio detection
What unusual hot spots, where and how were they distributed
What significance do you attach to the hot spots, are they on other windows
Is the voltage AC or DC
Use a voltage/cable detector around the window frame to ensure there is no old cable around or in the wall that should have been made dead.
Reply to Bizarre Wiring And Readings Through Upstairs Windows in the UK Electrical Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
