A client asked me to add two sockets in their bedroom
I took power from two sockets in the lounge which is behind the bedroom wall.
I ran a cable out of each socket for the new socket
The problem is it now is tripping the RCD and blowing the old Existing sockets and light switches
But the new sockets I added still work fine
The old existing sockets and switche are blown and unusable
When I try to reset the RCD It pops and Sparks down
Any idea to why this is happending
I'm not offended I asked a questions and want advice. I don't want to be asked irrelevant questions and be ridiculed
I said don't get offensive.
Asking you about your experience and knowledge of testing is about as relevant as it gets.
Have you disconnected your new cables from the old sockets and now everything is fine?
Either your new sockets are faulty (unlikely), or you've made a mistake.
Aside from trying to get a bit more info out of you about what you actually did I'm.not sure what else you expect from an Internet forum. There's not too many ways you could balls up a job like this really.
Thing is there isn't really a way to make a mistake it just running 2.5 out-of one socket into another. That's why I'm so baffled
You really need to be doing some IR testing to solve this. It sounds pretty basic and should be easy to get to the bottom of with the right test equipment. Can you get someone you work with to help? Someone with proper test equipment. A £10 Kewtech socket tester doesn’t count!!
