schoe
Just out of interest if i was to fit a new dual rcd split board and a came across a borrowed netural on a lighting circuit how could i resolve it?
Thanks Chris
Thanks Chris
Hence competent persons onions: or shall we just be like america and prevent anyone swapping like for like (old for new) fronts etc....Its up to the homeowner after all whether they employ anyone to do the work for them or not........telectrix that is fair enough because you are giving somebody/homeowner information they need to know because changing a fuse is within there capabilitys, but anybody who is removing the switch should have sufficient knowledge.
so you dont have a duty (moral or otherwise) to forwarn anyone else coming after you (competent persons) of this scenario?..........unless competent in the task you are undertaking do not proceed it is simple, so are you telling me you see a problem with a 2 gang switch? so you note every 2 gang switch on a PIR, move into a large scale property and your PIR will turn into war and peace. it does not need noting or labeling end of, lets not wrap our job into anymore red tape than it already is.
