Brick lights in timber | on ElectriciansForums
Discuss Brick lights in timber in the UK Electrical Forum area at ElectriciansForums.net
Hi there. I am just about to start a job that entails installing a load of brick style lights into railway sleepers. Any thoughts on the best way to cut the hole out? I was thinking of drilling a load of holes with a wooden spade bit inside the shape of the hole then chiselling any corners out. Does anyone have a better idea???!
Thanks,
Dave.
Thanks,
Dave.
Depending o how deep you need to go
Thanks,
Dave.
I'd throw a multitool into that equation if you have one.
Nice quick replies! Thanks very much! I do have a multi cutter. They are standard blades so not sure if they will do the 60mm deep that is required. I will.have to check in the morning!
here you go.
[ElectriciansForums.net] Brick lights in timber
Reply to Brick lights in timber in the UK Electrical Forum area at ElectriciansForums.net
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
