Burglar Alarm and Speech Dialer | Page 2 | on ElectriciansForums
Discuss Burglar Alarm and Speech Dialer in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I'm sure the wiring is correct. It's hard to get wrong
- - - Updated - - -
Really appreciate this by the way
From memory there is an engineers hold off, and now the wiring looks all ok, and the jumpers are in sab and batt on, you should be able to put cover on and take engineer hold on...off from the panel.....check odyssey manual, i think its 3 stobe triggers in 30 secs, done by strobe test on panel...this will the enable the bell box
I go into the test menu, activate the strobe 3 times and the LED on the right side of the bell box just keeps flashing to say that it is in hold off mode. What can I be doing wrong?
Says hold off mode automatically turns off when the tamper circuit is closed and the power is supplied from the control panel
Reply to Burglar Alarm and Speech Dialer in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
The previous bell box worked fine. I think it was just lacking the added security of anti tamper. Can this one be wired the same?
Shhh, don't tell the Chinese they want a bit of the action.
