Burried SWA for a log cabin | Page 3 | on ElectriciansForums
Discuss Burried SWA for a log cabin in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
Hope someone can give me clarity around the need to bury an SWA cable please.
I've been asked to install an 4mm SWA from the main DB to a "to be built log cabin" at the end of the garden about 50m away, it will need to run along a fence for most the route (or underground).
I called NICEIC to clarify and they advised I cant clip it to the fence incase it falls down, cant leave it on the surface due to rodents and have to bury it for the entire length. My question is reg 522.8.10 says "burried cables shall be buried to a sufficient depth to avoid being damaged...." what do you guys call a sufficient depth and whats your thoughts about rodents chewing through SWA armour???
Basically what do you guys do in these cases??...
Many thanks,
M
For volt drop on 4mm SWA over 50 meters you are looking at no more than 14A to get below 3%
The regs really need to bottom this. They put depths for other areas why don't they do it for domestic?
More to the point, why don't people use 600mm as specified in the regs.
One of the main things advised is "considering the future disturbance of the ground" A green patch of lawn would be completely different to an agricultural field for instance.
I’ve buried some swa in ducting in my garden. Probably no more than 50mm under the ground, no yellow tape. It’s under some artificial grass or slabs, so no digging likely.
And you know it is there and there will be information left for future occupiers or anyone who would want to disturb it. That's the way it should be done . It is all about consideration and common sense. :)
Reply to Burried SWA for a log cabin in the UK Electrical Forum area at ElectriciansForums.net
