I would just put a steel 25mm conduit with endbox behind consumer unit straight up into the loft in the corner if you can (im asumeing con unit would be in a corner), then you can pull in what you want at later date.
On the timber frame houses we do we stick a 25mm plastic conduit straight to loft for solar at later date, and its behind the stud work so it will be 125mm back from the surface too.
I would advise however to install inverter else where, im not keen on installing them in lofts although many do.
SWA may not be regarded as sufficient protection against nails and the like if burried in a wall less than 50mm. neither is metal capping.
No, you're right Gavin, never on a shared RCD. Most TL manufacturers will tell you that their unit exhibits about 20mA AC leakage under normal operating conditions. Odd though, that SMA "recommend" a 100mA min trip limit (to avoid nuisance tripping) and I could be mistaken but didn't P1 always recommend a 300mA trip limit, per inverter - although that could be due to the fact that most of mainland Europe (especially Germany curiously) don't consider a 100mA trip limit RCD as a standard rating, normally using either 30mA or 300mA.
So, we know in practice that a 30mA limit on a dedicated circuit is generally ok with a good quality TL unit (damp mornings are when a problem will typically materialise as we know) but on the other hand we have manufacturer's recommendations to follow....what to do? ;-)
which is why I didn't understand your previous post! Hence Huh!
