Cable size | Page 9 | on ElectriciansForums
Guest viewing is limited
Discuss Cable size in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
I am going to be connecting an out door power supply, away from the building, its all metal casing.
The supply is 10mm, I am using a 3 core SWA for part of the run, the inside part was going to be in twin and earth, but then I was just thinking, going on table 54.8 section 544.1, am I looking into this too much or does it need to have a 10mm earth as its extraneous metal which is fixed into the ground?
In which case I was just thinking of running 3x 10mm inside the building so the earth is 10mm too to them comply with min size of bonding conductor.
I am right to make it 10mm throughout the entire run aren't i?
It just does not. I am not dismissing you or belittle your post. I am all ears and would like to understand more. I would have though somewhere in BS7671 it would say something like to earthing systems cannot be in one location. Guess guess guess. Not fact!!!!
don't get many swimming pools on the railways although the unions are thinking about this 'right' in there current talks.
You aren't mixing earthing systems.
A PME supply has an earth rod connected at regular intervals from the substation right up to the end of the cable run. All you are doing is adding another electrode which is connected at the MET of the installation. The big danger with PME is when the neutral becomes broken between your installation and the DNOs earth rods, having your own rod connected to your installation mitigates the danger in your installation.
see post 122
Wont the fault then take the path with least resistance which is bound to be the PME earth which pretty much makes the earth rod pointless?
not pointless. in the event of the supply N being lost, the rod will provide an alternative earth path for a fault on the installation.
Not to the MET. The rod would earth the VCP only.
You say not to the MET...
Why doesn't it sound right? Adding an extra earth electrode to the PME supply is only going to improve it and make your installation safer in the event of an external neutral fault. This is exactly what is recommended in the regulations for swimming pools fed via a PME supply and is required practice for PME supplies in other parts of the world.
You say at the end of the circuit.
no connect the rod to the main earthing terminal not at the end of the circuit
You say to the MET
I have no reason to disbelieve what these guys are saying with regards to earth ridding to the MET.
You are now saying to the MET.
Which is it??
So are you saying connect the rod to the end of the circuit yes?
No, although this is my opinion only at the moment as I can't reference regulations off the too of my head, my logic is as follows.
This earth nest (not just a rod, multiple rods interconnected) is going to have a low (sub 2 ohm hopefully) Ra so it will see its share of diverted neutral currents from the whole installation. I would prefer that this wasn't flowing through the circuit CPC so that of anyone working there in the future disconnects the circuit they aren't going to get a surprise when they disconnect the CPC.
Can I not connect it to the armouring to take it back to the MET or the CPC of the circuit? Do I have to run in another 10mm earth, I then have the hassle of protecting the earth cable when it leaves the wall and into the ground...
Reply to Cable size in the UK Electrical Forum area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
Recommended Sponsor News
Hi everyone,
