F
fivestar
I am carrying out a major re-wire on a farmhouse which is also having a substantial extension. Can I run the t & e cables for the socket outlets on top of the concrete subfloor - they will be protected by the kingspan insulation from the floor screed when it is poured and as they are in contact with the ground directly should not be a problem with heat.
