Cables in concrete floor | Page 3 | on ElectriciansForums
Discuss Cables in concrete floor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can I be blunt please/ why go to all that trouble fitting saddles, fitting angle boxes etc, when the best way would be to go from Socket to socket the shortest way possible, make slow bends etc, by the look of your installation most of the links between outlets could have been tubed within the dot and dab install on the wall, it's a nice neat job, but completely over engineered IMO
It will be very busy up there with the lighting, plus I want to avoid cables running up behind cupboards, as we won't see those being installed (and cables drilled into!).
That is mad really, you should have come down from above. That would create safe zones. If you have dot and dab plasterboard going in, he is going to be annoyed. You should have twin and earth clipped to wall, otherwise it will hold boards off too much. He will probably now batten it off and you will wish you installed deeper boxes. Have you got 50mm m3.5 screws on your van??
Do that all the time with kitchen refurbs, just look at the kitchen unit plans, and make sure sockets etc (drops) are positioned away from wall unit fixings, and as Pete said run horizontally as well.
Haven't done it yet, so still have time to consider a plan.
The picture is of Pennywise's installation from 6 years ago, which was dredged up and re-animated by someone looking to do something similar.
Pennywise doesn't appear to have been on the forum for a couple of years.
Reply to Cables in concrete floor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is an RSS feed of thread: Hole in copper pipe, solder under floor, T coupling & protection Content of the thread: I was stupid enough not to...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
