Cables in concrete floor | Page 2 | on ElectriciansForums
Discuss Cables in concrete floor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
No sorry that was from my wholesaler H&H electrical hersham no website i don't think give them a call if your not to far away.I lied they do have website just looked bugger all on there probably better phoning.
Hi, I know it's an old thread, but I've got a similar job coming up.
When you (or I soon), come up from the subfloor in conduit past the floor's dpc and up to the wall, is the conduit and socket boxes going to interfere with the plaster thickness?
Why on earth are there many conduit boxes,surely a couple of bends & kicks would of been a lot better .
I assume the wall is going to be dot and dab finished so the plasterboard will just be set on the adhesive blobs to the depth of the back boxes.
Hope you don't try putting tw&e through similar conduits?
I believe the rules are that if a thread is more than a couple of months old it pales into irrelevance and you are required to start a fresh one.
No problem, the thread can run, it's going to be difficult to split it now and there's recent commentary on Pennywise's old photo.
Reply to Cables in concrete floor in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
This is an RSS feed of thread: Hole in copper pipe, solder under floor, T coupling & protection Content of the thread: I was stupid enough not to...
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
