Cat5/Cat6 Data courses
E
eskimo39
Hi does anyone know of any courses in Cat5/Cat6 Tv, Data & CCTV installation courses.
Really fancy looking into this line of work.
acvc;104025 Or can you daisy-chain the sockets along as in electrical radial circuits? Just a rough guide would be brilliant while a start learning/finding a friend who can! Many thanks chaps and chapesses.[/QUOTE said:
you can daisy chain cat 5 but i dont recommend it
any break or joint in the wire leaves a weak spot open to corrosion and signal leakage.
an arcnet network can be daisy chained and is usually called a token ring lan.
this network generally uses rg type cabling and bnc connectors
heres a wiki on cat 5e and another on arcnet
Category 5 cable - Wikipedia, the free encyclopedia
ARCNET - Wikipedia, the free encyclopedia
hope these help
Cat5/6 etc twisted pair is designed to work as a star topology, not a bus topology like 10base2 thin ethernet is, so I would be surprised if it would work at all when turned into a bus! Would be a lot less fault tolerant too. Just take a separate cable from the origin to where it is needed.
That is the reason I don't recommend it.
I did it once for a tightwad boss even after I told him there would be problems with it, he still wanted it done that way.
I was called back to change it a week later.
Got paid twice for it.
yes it worked but you could only use one computer on it. any more would have caused data/ communication faults
but you had multiple places you could connect to.
i told him it would only work like that but he didn't believe it.
ran new cables to each box to a hub so they could use more than one computer
eskimo39,
gnuuser,
