Deleted member 26818
Yes Bruce exactly, a MEIWC is an alternative to issuing an EIC.
Discuss certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So If assessor says otherwise after making him read it i will make him eat it lol
cheers to all I was going to ring him again in the morning to re question him on it but cant be bothered if i am honest with you
at this rate i may as well give him one of each for good measure lol
The EIC should describe the extent of the work covered by the Certificate.
You should only record the results of inspecting and testing the work covered by the EIC.
If you inspect and test any of the existing installation, then you are effectivly conducting a Periodic Inspection, something that the BS7671 prohibits an EIC being used for.
Hi mate
so for the new shed supply and the CCU change am I supposed to carry out a full inspection & test of the installation including existing circuits or just the shed supply and any circuits that are new or added altered that i have carried out work on as surely when you change the overcurrent protective devices by providing a new CCU this would require a full set of tests
Reply to certification in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
