Changing main switch on CU | on ElectriciansForums
Discuss Changing main switch on CU in the UK Electrical Forum area at ElectriciansForums.net
W
watson650
Hi all
Just looking for some advice pls. I've been told that I need a new CU as the existing main switch has the wrong rating. Isn't possible to just change the main switch. Existing CU is Marbo.
Many thanks
Hi Watson, remember your main switch is exactly what it says on the tin 'a main switch' all of your sub-circuits will be protected by MCBs/RCDs, in all likelihood your tails would be 16mm anyway. Obviously I haven't seen the job but I would guess you are ok with the 80amp main switch.
Reply to Changing main switch on CU in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Try to keep this nice and short. Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
