Chasing out | Page 4 | on ElectriciansForums
Discuss Chasing out in the UK Electrical Forum area at ElectriciansForums.net
P
PeterPan27
Just i simple question peeps.
When chasing out a wall to fit 1.5 twin and earth how far do you have to chase? 50/65mm? Also you cant just plaster over the cable cause thermal insulation.. whats the plastic cover called? which you place over the cable then to plaster/fill over?? and is this tacked into place with small nails?
Sorry if its a stupid question. so far all my work has been done on metre square boards lol
No the coffee table is just there to protect the twist and taped joint. you know, in case the dog starts sniffing around or the 3 year old mistakes the connector block for lego. It's called providing a barrier DPG, jeez, don't you know anything.
I call mine George, but you can call yours anything you like - as long as it doesn't hear you. :joker:
Reply to Chasing out in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
