Was thinking either that or the boiler feed (fused down to 3A at the boiler).maybe there is an immersion heater lurking away where it can't be found.
Discuss Code 1 Problems - Am I being Scammed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for all the replies guys. I will be using all of this when speaking to the electrician later. One thing that does spring to mind. On my driveway I have a montion sensor activated lamp which comes on when anyone is within the vicinity of the front door. Could this be why he has given a Code 1 on No RCD protection?
I doubt it unlessit has a 13A socket built into it which you can plug your mower into!
That's a good thought, and might explain a lot!I'm thinking that the Electrician might not be registered for Part P, and that the price includes the notification fee.
Is the board change on advise of the letting agency that they require all the properties to have RCD protection ?
I know that quite a few uni's and agencies have a stipulation that all properties must have RCD protection, I just wonder if your agency stipulated same, and the sparks was informed of this?
Saying that the 150 pound price for an hours work does seem excessive, and his coding does leave a lot to be desired. Can't make out why he has LIMITED the 2 circuits on the IR test, and still managed to carry out an R1 + R2 on them.
Reply to Code 1 Problems - Am I being Scammed? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
