Commercial PIR on a LARGE site. | Page 3 | on ElectriciansForums
Discuss Commercial PIR on a LARGE site. in the Business Related area at ElectriciansForums.net
In that situation, we would propose a full test and a 20% inspection.
If significant defects are revealed then the inspection percentage should be increased with agreement from the client as additional costs will be involved.
The primary reason for sampling is that faults would be introduced as a consequence of mass dismantling of the installation.
IQ,
Sorry for the late thanks but much appreciated. ive discussed this with the Customer and aside from confirming the pricing, we are looking to go with Testing plus 20% inspection plus increase as problem found etc.
Most of the works i have seen are likely to be remedial related unless the testing starts to show anything really untoward. Finally making some headway with this i think.. still very daunting though!
Theybe got lots of work needs doing along with the testing and now the PAT testing i due.. might aswell sign myself up for the year! :D
Make hay while the sun shines!
You'll find most of your defects will come from the visual inspection, damaged accessories, IP problems on DB's and panels etc.
Most of our testing identified defects are failed RCBO/RCD's, low IR's on older installations, and the odd exceeded Zs.
The PAT price is getting hammered at the minute, ridiculous prices reflecting the fact that anyone can be a 'PAT tester'. We stick firmly to our price per item unless there is an unusually large quantity, let the 75 pence an item brigade take it if they want it, we can't make money on that.
no a full test of every circuit is required that will give you a base to monitor the condition for the next inspection , appart from all the testing what i would recommend is you lable the dist boards as you do them if there are more than one also lable the sockets switches outlets with whickh DB they are from and associated circuit 1 it makes life easier and you know what youve tested and also in the future if you have any work from them you can identify the circuits quickly , you have to identify every thing when your testing its so easy to do a quick lable ive just done a wholesalers with 14 Dist boards started off with DB1 which was the main one and ended up with DB 14 labled with 24mm yellow and black letters/numbers and 12 mm lable for all the accessories
20% Inspection in my world means 20% sampling, because a full visual is the norm lol
Absolutely, by inspection, I mean actually dismantling accessories etc.
I'd also get the labelling bit cleared up with the client, we always supply DB schedules as part of the inspection because it's the flick of a button and the printer does the rest but on the sites that we do with 1000+ circuits, it would be impossible to include labelling of accessories (there will be thousands) in with the standard PIR rate.
That's the thing, if you pick on areas where you think labeling is required ie a bank of isolators not identified as to what they do, you would put that in with the report, then its up to the client what they intend to do about it.
I don't think people fully understand the concept behind PIR'S.
Just as a point of interest.
What code would you apply to lack of circuit identification in this or similar instances?
Would your choice of code be affected by the number of unidentified circuits?
I thought IQ meant was as he said only dismantling say 20% of the faceplates / accessories etc.
Really appreciate everyones input thank you. Makes it easier to clarify all points with the customer prior to starting.
[FONT=&quot]The service head and the main switchgear are located within cupboard adjacent to Gas intake cupboard. There are no circuit charts or installation records installed adjacent to the mains position.
Someone want to code it to see what people come up with? it is a real finding by the way.
[/FONT]
It would depend on the use of the building, you need to assess the impact of the lack of labelling.
Is it safety or inconvenience?
A factory full of guys who've worked there for years will have no problem knowing which isolator relates to which machine.
A school metalwork classroom is a different kettle of fish.
On my report, one scenario would attract a code 4, the other a 2.
IQ - My question relates to the main panel/switch gear for a residential building. Feeds all the dwellings and landlords etc, the building had no maintenance programme in place and was just looked after by a warden.
Well there's a definite safe isolation issue there, I'd want to see at least identification of each distribution circuit so I'd allocate a code 2 to that.
That's what code I gave it. I ripped the installation to pieces along with another 3 courts, all a fair size.
Never got the remedial works, heard a rumor that, the reports and test schedules got stuffed in a draw, the authority did not want pay to put everything right.
When they advertise for the odd Electrician they won't give me an interview.
Reply to Commercial PIR on a LARGE site. in the Business Related area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
I would expect it to be virtually impossible to complete the project safely. how would you fix the panels to a roof that you can’t disturb? when...
