Commercial PIR on a LARGE site. | Page 5 | on ElectriciansForums
Discuss Commercial PIR on a LARGE site. in the Business Related area at ElectriciansForums.net
ok normally when you do readings on larger cables the r1+r2 come out around 0.00 as the furthest run is around 20m
isit worth doing these
Unless there's a client specification, it's your decision as the inspector to decide which tests are appropriate on a periodic inspection.
Reply to Commercial PIR on a LARGE site. in the Business Related area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
I would expect it to be virtually impossible to complete the project safely. how would you fix the panels to a roof that you can’t disturb? when...
