Guest viewing limit reached
B
brizospark
In the wholesalers today the manager said he had seen an attachment for a battery drill that will thread 20 / 25mm steel conduit
Has anyone seen these or know where to get hold of one?
Nah they are pretty slow.And is it idleness to use a hammer drill and not a rawl plug tool and hammer?Move with the times
I think the professionalism of opinions on this forum actually shows exactly how much everyone DOES move with the times, both technically and practically, and you'll find a gadget for most jobs in my tool box too, but the point being made is that sometimes you just can't improve on the tried and tested. Patience is sometimes the sharpest tool.
i liked my rawl tool,we learned how to use them at college,an old technical college i may add,christ i didnt realise i was that old..and i remember going to newy's and asking for a bundle of galv (and a new die) and a bucket of water for the horse as the trek from the site on those winding roads took it out of the old gal..:D
You will end up with either knackered arms or a knackered drill
There is a tool available for this job,it runs well when programmed and will cause you little in the way of effort
Not sure of the modern name but it used to be called a mate
But how can you make a decision if you haven't used one?Sounds like not allot have and are slagging it!Anyway each to there own.Not saying i would go out and pay all that money for one but it was on a job there to be used and i did!Along with another ten sparks
i like the normal way.
l
I never thought the ideal tool was manufactured with us scrawny sparks in mind
Bolt & Pipe Threading Machines - Heavy Duty Bolt Threading Machine 1/2" to 2.1/2", 2.1/2" to 4", 2.1/2" to 6", Pipe End Facing Machine 2.1/2" to 6", Pipe Threading PVC 1/2" to 2.1/2", 2.1/2" to 6", 4" to 8", Pipe & Bolt Threading & Tapping Machine 1/
I'm all for working smart and saving time but I don't see it being easy to thread steel conduit with a cordless drill. Is the device aimed at the commercial contractor or is it more of a DIY gimmick? I would definitely try the thing out before you part with your hard earned cash.
Seems to me n all that theres a "fear factor" about hand tools that require a bit of effort.....colleges do and should continue to teach how to use diestocks as basic engineering skills.....when i worked in fabrications we had allsorts for running a thread on stuff...roller boxes, die boxes (for the ward 7s) tapping chucks for the radial drills but sometimes its just better to use your brawn.....as with conduit threading.........
For me, the task here isn't precision engineering, but at the same time, its quite a precise practice and my personal preference would be to do it by hand rather than use a drill and risk making a mess of it by over turning. If its too tough, perhaps a few good hot dinners are called for ;)
takes quite a bit of effort/time to make a runner using stocks and dies especially on 25mm conduit
i always use my stocks and dies though its good exersize
There's a whole machine for threading conduit, it looks like a drill with an attachment but its purpose made, there's 110v and 36v ones, the 110v ones are about £250.00 and the 36v ones are about £700.....they have changeable heads and do from 10mm to 30mm or therabouts on the 36v ones and up to 40mm on the 110v ones..... a bit like the machines that you see pipefitters using to thread big pipes only a lot smaller....
I have never seen sparks using them, only plumbers working with small steel heating pipes before they get the loctite55 out but we could use them, it's just that we use the tap and dye sets and the old yellow bender/vice......
There are also plumbing crimp machines made by the same company that look similar and come in 110v and 24v versions... I think it's the manufacturers that do the Battery crimpers we use to do big SWA's with.....but I can't remember the name, it was German.....I can have a look around...
Ive seen a drill attachment that wipes your butt for you, it like a circular sponge attachment and saves you precious seconds but im never gonna use one again as i left my drill on hammer....:sad3:
Conduit Threader for drill
Australia
brizospark,
Dan,
