Connecting a shaver point to a shower circuit. | Page 3 | on ElectriciansForums
Discuss Connecting a shaver point to a shower circuit. in the UK Electrical Forum area at ElectriciansForums.net
ChrisElectrical88
Mentor
Nearly Esteemed
Wales
Hi. I want to install a shaver point in a bathroom for a fussy landlord, but she only wants it to be used when the shower is on, not sure why. I am going to wire it off the shower circuit and cut down the cores so I can fit them all in 15A connector blocks in the loft. Is this ok? If not what regulation prevents thing?
Ok let's make this really really simple.
If you carried out a domestic EICR and came across a fan spurred from a shower circuit and fused as per the previous post what code would you give it and why ?????
i'd give it a C3. as " improvement recommended IMO". that's not to say that it contravenes a specific reg. just that i'd like it improved.
Mechelec, thats a bit unfair.....I put forward quite a strong reason not to proceed with an extract fan connected to the shower.
These fans usually require a 3amp fuse (manufactures instructions) and in this instance the OP had suggested 2No FCU ie a fuse on the live and a separate fuse on the switched lived. This would effectively create 2 new circuits sharing the same neutral and as such is non compliant with BS7671...borrowed neutral
how is it a shred neutral when the fan sub-circuit is now part of the shower circuit? remember that a circuit starts at the point of origin. in this case the MCB in the CU.
Sorry zebra you are right that would be a poor idea but my suggestion was for no run on timer fan only on when isolator is on.
see telectrix good answer above.
One reason could be not complying with the building regs on a new build.
Circuit definition is 'an assembly of electrical equipment supplied from the same origin and protected against overcurrent by the same protective device(s) therefore IMO the 3amp fuses are the same as two diffent MCBs in a DB sharing the same neutral....borrowed neutral...the origin for the fan is now the 2No FCUs
The supply would be to a fan wired in 4 core flex more than likely. Would you really be disconnecting any core of the flex without carrying out safe islolation ?
Sorry I Can't insert smileys on my generic tablet but believe me I am smiling.
i have been trying to encourage friendly debate and this subject seems to have rattled a few people.
Still waiting for a good reason though lol
The problem here is what people consider 'bad practice'...
There is no 'bad practice' guide or 'good practice' regulation book so examples of 'bad practise' are based on one's:
Personal experience/opinions.
Something one has heard from a mentor that one respects (often in training/apprenticeship).
Interpretation of a regulation (admittedly not always entirely accurate).
There may be (technically) nothing wrong with what you propose, it just may be 'against the grain' in the opinion of many on this forum.
Bear in mind though - many on this forum (I will not mention names for the fear of swelling heads) are experienced and their view has merit, so when someone says, eg, fit a PIR to control your fan, take it as good advice!
Reply to Connecting a shaver point to a shower circuit. in the UK Electrical Forum area at ElectriciansForums.net
I went to look at a job like this a few years ago. My customer had a rental house, where there was an upstairs bedroom that had a newly built stud...
    • Informative
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
