Consumer unit change with a fault! | Page 5 | on ElectriciansForums
Discuss Consumer unit change with a fault! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening all..
I have just changed a CU. I did find a neutral - earth fault prior to the change so I thought I would probably have a tripping RCD.. which I did!
My dilema is how do I proceed with the paperwork?
I'm going back tomorrow morning to do all of the testing and I shall give the required certificates (with a note on regarding neutral/earth fault on downstairs lights), but I get the feeling the chap is going to hunt for the fault himself, the reason being it will require the floorboards being taking up and he doesn't want to incur anymore cost (fault is in a junction box(s), under the floorboards that someone has kindly wired all the downstairs lights from - took me a while to figure this out!)
The main point being that the work is notifiable, but I cant notify it if it still has faults! How do I proceed?
I realise I should have perhaps corrected the fault before the CU change, but the chap just wanted the new CU in and due to my inexperience I wasn't sure if the new CU would trip!
Cheers...
Cast iron bath - lump hammer, thick gloves, ear defenders, eye protection
edit: unless you're the tat man, in which case forget ear defenders or gloves or eye protection, replace with manky tracksuit, trainers, spliff in mouth, spots, and the axe/maul that was the nearest thing available, that Rick-O-Shea's (can't spell proper word) off the bath with the axe cleaving bit narrowly missing ones lower leg each time its swung.
how cynical of me
Reply to Consumer unit change with a fault! in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
