Consumer unit change with a fault! | Page 7 | on ElectriciansForums
Discuss Consumer unit change with a fault! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening all..
I have just changed a CU. I did find a neutral - earth fault prior to the change so I thought I would probably have a tripping RCD.. which I did!
My dilema is how do I proceed with the paperwork?
I'm going back tomorrow morning to do all of the testing and I shall give the required certificates (with a note on regarding neutral/earth fault on downstairs lights), but I get the feeling the chap is going to hunt for the fault himself, the reason being it will require the floorboards being taking up and he doesn't want to incur anymore cost (fault is in a junction box(s), under the floorboards that someone has kindly wired all the downstairs lights from - took me a while to figure this out!)
The main point being that the work is notifiable, but I cant notify it if it still has faults! How do I proceed?
I realise I should have perhaps corrected the fault before the CU change, but the chap just wanted the new CU in and due to my inexperience I wasn't sure if the new CU would trip!
Cheers...
HHD I’m not sorry for my comment. I really don’t think you are competent to work alone.
If you can get to shadow someone then do so. When it comes to faultfinding there are so many tricks to learn. Tricks that save you time and build your reputation.
Faultfinding:
It’s a double edged sword:
A/ find it too quick and it’s “he charged £---!”
B/ too slow “messed about for hours at £---!”
Take it from me, you learn to play a game.
I’ve never done domestic always heavy industrial. I had to justify my existence on the pay role, believe me play acting came in to it in a big way.
I should have been a plumber, bullsh1t baffles brains.
97 Now
Cast iron bath - lump hammer, thick gloves, ear defenders, eye protection
edit: unless you're the tat man, in which case forget ear defenders or gloves or eye protection, replace with manky tracksuit, trainers, spliff in mouth, spots, and the axe/maul that was the nearest thing available, that Rick-O-Shea's (can't spell proper word) off the bath with the axe cleaving bit narrowly missing ones lower leg each time its swung.
how cynical of me
Reply to Consumer unit change with a fault! in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
2 3
Recommended Sponsor News
Hi everyone,
