Guest viewing limit reached
A
amberleaf
O.S.G.. The use of other methods’ of determining Maximum Demand is Not Precludedwhere Specified by the Installation Designer
FirstlyI make no Apologies for the Way am Writing on any Matters . it can be a first day Apprentice or some one Needing aJog of Memory .
Sowe are all in the Same Boat . “ To Learn “
For the Apprentices . The Day we stop learning is the Day we hang Upour Tool-Bag
CookerDesign Current Calculations
Thefirst thing you have to do is get Your Head around the Calculations !!
(From a Design point of View ) 2392-10
DomesticInstallation Oven(s) & Hob(s) are to be Calculated upon their MAXIMUM LOADING
Startwith a simple Calculation ( An Oven has a rating of 2kW ) 2000
(I = P/V ) Formula … I = 2000 ÷ 230V = 8.70A …. Weare Using the Unit Amps
2392-10/ Domestic Installation Oven(s)
Ovenhas 4 Rings ( 2 x 1kW ) & ( 2 x 1.5kW ) & Grill ( 2kW ) & Oven (3kW )
-Controlled via a CookerSwitch with a Socket outlet .
Asa Designer . we’ll have to Apply Diversity ??
Important )- Diversity allowance to be Applied to the FULL LOAD CURRENT for CookingAppliances .
TheO.S.G. is telling us . Purpose of the Final Circuit fed from theConductors )
O.S.G.Table 1B p/97 – column (3) Cooking Appliances → At the Top of the Page Note : Type ofPremises ( 2392-10 → Household Installations ) Domestic Installation(s)
DomesticInstallation(s) Only O.S.G. - 10A + 30% f.l – Full Load ) of connected Cooking Appliances in the Excess of 10A+ 5A if a socket-outlet is incorporated in the Control Unit . ( C.C.U. ) – 45A + 13A Socket Switched with Neon .
Fromyour point of View ( The First 10A ofthe rated current plus 30% of the reminder ( Plus) 5A if the Control Unit incorporates s Socket.
Calculations)- You bank “ Hold OFF“ the first 10 Amps of the Maximum Load Current )
The10A will be used at the End of the Calculations’
-So your Work out the Total Power Rating & then calculate the Full Load Current
Calculations)- Power = ( 2 x 1 ) + ( 2 x 1.5 ) + ( 2+ 3 ) = 10kW
I= 10000 ÷ 230V = 43.48A … round it up to the first four numbers43.47826087 ( 48 ) 43.48A
UsingDiversity allowance stated ↑↑ ( 43.48A sub 10A = 33.48A )
I= 33.48 x 30 ÷ 100 = 10.04A
Youradding the ( 5A ) for Socket outlet . I = 10A + 10.04 + 5A = 25.04A )- Asa Designer this is your Expected Current Demand .
Remember )- Supply Cables Rated to suit DesignCurrent ( Iz ) :)
542.2. Earth Electrode(s)
542.2.4. The type & embedded “ DEPTH “ of an Earth Electrode shall be such that soil drying & freezing will NOT increase its résistanceabove the required value .
UsefulJunk .
Earthing Clamps . & Labelsto ( BS-951 ) must always be used .
Possibilityof corrosion the clamps should be of the ( Blue Type) Larger sizes of conductors are used then the ( GreenType ) more suitable .
( Red Clamps ) are for used in ( Dry Conditions )
( Blue Type ) & ( GreenType ) can be used as these are suitable for Non- corrosive as well as Corrosive Conditions.
2392-10: Initial Verification .
Onthe completion of an Installation . it is aRequirement of BS-7671:2008: No 1 . That a Certificate is Issued to SHOW that the Installation is COMPLIANT .
2392-10: The Verification .
Mustbe carried “ OUT DURING “ & on COMPLETION of the WORK .
YourGain is . Initial Verification .
611.1. Inspection shall precede testing & shallnormally be done with that part of the Installation under Inspection ( DISCONNECTED ) from the ( SUPPLY )
Whatthe First Amendment . is saying . Wording .
610.5. On COMPLETION of Verification . according to Regulation 610.1. to ( 5 ) a Certificate shall be prepared .
Asan Inspector . 610.5. The Verification shall be MADE by a COMPETENT PERSON .
Chapter 31 . Purposes . Supplies & Structure .
p/47. 314 :Division of Installation .
314.1. : Diving the Installation into circuit(s) so as to :-
(i) Avoid danger& minimise inconvenience in the event of a fault .
(ii) Facilitate safeTesting . Inspection & maintenance .
p/46. □ 314.2.
Separate circuits shall beprovided for parts of the Installation which needs to be separately controlled. in such a way that those circuits are not affected by a failure of othercircuits . & due account shall be taken of the consequences of theoperation of any single protective device .
p/46. □ 314.3.
The number of final circuits required . & the number of pointssupplied by any final circuit . shall be such as to facilitate compliance withthe regulations of chapter 43 for overcurrents protection . Section 537 for Isolating& Switching & Chapter 52 as regards current-carrying capacities ofconductors .
p/19. 132.3. Natureof Demand
□ changes are incorporated in Part 7 .
Section 701 : Locations containing a Bath or Shower basin .
□ Zone ( 3 ) is no longer defined .
□ Each circuit in a the Speciallocation must have ( 30mA RCD protection )
□ Supplementary bonding is NO longer requiredproviding the installation has main bonding in accordance with Chapter 41 .
This section now allows socket-outlets ( other than SELV &shaver supply units to BS-EN 61558-2-5 ) to be installed in locationscontaining a Bathor Shower ( 3m ) horizontally beyond the boundary of Zone 1 .
Résistance “ -&-s 2392-10 . will come Up . Q/As
ofan Object is affected by :- :banghead:
□ Length / Résistance is directly proportionalto ( Length) Two materials of ( Equal Length ) & Cross-sectional area joined together ( Doubling Résistance )
□ Area /Two materials of ( Equal Length ) & the same ( Cross-sectional area ) joined side by side will ( Double the Cross-sectional area& Halve Résistance ) Résistance & area are Inversely Proportional .
Resistivity
□ Is the Amount of Résistance in a conductor & will change according to (Material ) ( Size ) & ( Distance ) the current has tomove in the Object . ( Cable )
Temperature
□ when temperaturefluctuates . This affects Resistivity . ( Most Conductors)
( Most Conductors ) have increased résistance with increased temperature.
Carbon is the Exception . résistancedecreases with Temperature .
Star Connections
□ are usedfor an ( UnbalancedLoad ) & are a Neutral connection with an ( Untapped Earth )
Delta Connections “ □ are for a ( BalancedLoad )
( Vd ) - Voltage drops . because the ( Reissuance) of the conductor becomes ( Greater withthe Length of the Cable )
p/304. Appendix 4 of . BS7671:2008. No 1 . gives a table of values for Cable voltagedrop in ( millivolts . per ampere . per . metre . ( mV /A / m )
Calculation’s )- This is multiplied by the circuit’s designcurrent ( Ib) & the Length of the cable inMetres ( L ) & divided by ( 1000) to give the Total Voltage Drop for aCircuit .
Voltage drop . is calculated using the following Formula . ( Voltage drop - Vd. = mV / A / m x ( Ib ) x ( L ) 1000 .
2392-10 : ( NameTwo Items ) Confirmed at the same timeare ( Polarity) & the ( R[SUP]1[/SUP]+ R[SUP]2 [/SUP] ) valueof the circuit . ( T ) Q/As .-&-s .
Client ” is the person who ordered the work & will. at the end pay the bill . 2392-10 .
Certification& Reporting . ( T ) -&-s . Q/As
□ TheSingle signatory form is used when the Design. Installation & Inspection & Testing is the responsibilityof the same person .
□ TheMultiple signatory form is used when the Design . Installation & Inspection& Testing is the responsibility of different persons .
(ix) – p/389 . When making out& signing a form on behalf of a company or other business entity . ( Individuals ) should ( State ) for whom they are acting .
UsefulJunk .
Reason. Lighting .
Choke “ producesa ( High Voltage) when it is ( Open Circuited UnderLoad ) This high voltage causesthe ( Tubeto Strike ) or ( Switch On ) The choke also limits the Current to a ( Predetermined Value)
I would Like to “ SAY “
For allthe Unsung Hero’s ( Members / Mods ) . That give up there time Freely to supportthis Forum . &keep it running without Questioning its Principles’
HAPPYNEW YEAR . Old Amber :17:
UsefulJunk .
The( Light ) emitted by Mercury Gas Discharge . :13:
Whichis mainly ( Ultraviolet ) is converted to (White Light ) when it strikes the Phosphor Coating .
As. Earthing & Bonding is Two different Words .
p/23. Bonding Conductor . A protective conductor providing equipotentialbonding .
Bonding :- Thelinking together of the Exposed or Extraneous metal parts of an ElectricalInstallation .
***Cont../ Useful Information for Electricians & Apprentices***
Australia
amberleaf,
Dan,
