I recently fitted a new contactor three phase 10amp with 230volt coil, now it was working fine for about two weeks and now seems to have burnt out. I can not manually push the contactor in even using a screwdriver as it is solid. The overload is set to 4 amps so shouldn't be a problem with that has anyone have any ideas why it has burnt out? I have heard it could be caused by a drop in voltage on a phase but what would cause this as it all tested out at 230volt before it went wrong.
