Converting to a TT system... possibly | on ElectriciansForums
Guest viewing is limited
Discuss Converting to a TT system... possibly in the UK Electrical Forum area at ElectriciansForums.net
london
1.25ohm external earth fault loop impedance on TN-S supply to building
Supply authority stated our only option is a TT conversion as they will not covert to PME.
What would be my best course of action when converting to a TT as the building is quite old and i do not want a 100ma main switch for diversity reasons and nuisance tripping, so Would it be suitable to convert to TT and have all final circuits in a RCBO with a board charge?
Thank you Midwest looking at page 33 is quite useful
on a side note i want to avoid hammering a TT rod through a gas pipe, i have never installed an Earth mat are these a viable option as the property is surrounded by soil/grass
A sweep with a cat, not the feline kind, should help you avoid any other services.
SDS adapter and you can have a rod in the ground in a few seconds with little effort.
One question, will the rod be a better bet than the poor TNS earth?
We install mats regularly.
You will still need to dig down about 300mm but you will be able to CAT scan the area accurately.
The reason mats are deemed safer is that most Permit to Digs instruct you to CAT scan every 300mm. You cannot do this when driving an earth rod in.
Reply to Converting to a TT system... possibly in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
