Converting to a TT system... possibly | Page 2 | on ElectriciansForums
Discuss Converting to a TT system... possibly in the UK Electrical Forum area at ElectriciansForums.net
london
1.25ohm external earth fault loop impedance on TN-S supply to building
Supply authority stated our only option is a TT conversion as they will not covert to PME.
What would be my best course of action when converting to a TT as the building is quite old and i do not want a 100ma main switch for diversity reasons and nuisance tripping, so Would it be suitable to convert to TT and have all final circuits in a RCBO with a board charge?
What is this SDS adapter as i normally use a club hammer?
[ElectriciansForums.net] Converting to a TT system... possibly
I screw an earth rod driving bolt 5/8 into a rods coupler, then use an sds nut driver with the appropriate size socket, drill on hammer and rotostop. Don't expect to be able to use the nut driver and socket for anything else though
The DNO are obliged to maintain the earth they have there REG 25 ESQCR. Tell them you will take it up with HSE if they will not. They can put a steel band around the intake cable and braided earth from that. There is no excuse for them not to comply. Kick some arse!
The earth is in place and functioning.
Yes it is. May not be optimal but most likely all OCPDs will not exceed their maximum permitted ao what is the issue?
Max value for TNS is 0.85 off top off my head. That's what DNO's have to work to. Either it is, or it isn't.
Incorrect. It's well out of spec for a TNS system. Simple. Argue as much as you like, it's out of spec.
1.37 ohms max zs for a32 amp type B so unless your R1+R2 is ridiculously low then your max zs for this circuit will be exceeded.
I do not know what overcurrent protection is involved in this instance nore no of any rcd protection but no one in their right mind should except that ze measurement on that particular earthing arrangement.
I who hazard a guess that the DNO fuse would also not disconnect in the required time 5seconds if there was an live to earth fault on the tails.
Same statement could be said about a TT arrangement, however it’s not a TT arrangement at present.
Reply to Converting to a TT system... possibly in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
