Cooker Connection | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Cooker Connection in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
Ok, let me know what your thoughts are as to MCB size, cable size of cable from cooker to wall, nothing more, just let me know, then ill tell you what I have just found.
The cooker uses 10.4kW to 11.6kW, its free standing, 4 rings and double oven, new oven, well bought it off someone, but still has all labels on it etc, looks like its been used once. So lets just say on christmas day when you have stuff warning in the top oven, turkey in the bottom, and all 4 rings on boiling potatoes etc, the point is, it "could" draw 11.6kW.
1. What size MCB
2. What size cable for circuit
3. Size of cable from cooker to outlet.
my fav . is the one where they go to USA and DJ plays the mafia don as well as himself. that and the boat trip across the north sea.
I dont like the "Miami twice" episode...but the "Hull and back" is good. Thats the one where they are diamond smugglers. I prefer the older ones myself. Just after grandad dies and Albert turns up. Proper 80/90s classic sit com.
Best comedy moment ever!!!
I have the limited edition box set and still watch it on Gold...lol
Same here our lass bought it me for xmas, best present she's ever got me. And I also watch it everytime it's on tv, that part does baffle our lass.
But the point is that it couldn't.
What are you basing that on? As the oven clearly states that the max power draw is 11.6kW, so surely it CAN draw that if everything is on full? Personally I think connecting an appliance that has the potential to pull more than the circuit is designed for is wrong, ok i know that it possibly won't but its not the point.
Good lord above! Since electric machines were born into this world people have been developing our current system for diversity calculations.
Why is it necessary to question them now? How many cookers have the collected members of this site installed based on these diversity calculations?
You might as well start working with max current and max voltage instead of the RMS average if you are going to design cooker circuits based on max connected load instead of the load after diversity!
Do you actually understand how individual elements are powered and controlled?
If you are concerned set up a data logger and record the current draw from a cooker with everything switched at full at the same instant.
And then consider how many meals require every single element to be switched on at once?
This Christmas dinner you are always going on about, does the turkey go in the oven at the same time as the vegetables go on to boil? (They're going to be soup by the time the turkey is done)
In that case near enough every install is wrong.
Most installs could draw more than the supply if you turned everything on at once... Lol
Reply to Cooker Connection in the UK Electrical Forum area at ElectriciansForums.net
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
Recommended Sponsor News
Hi everyone,
