Guest viewing limit reached
I was called to a house where they said the fuse for the sockets kept blowing.They had kept replacing the fuse until it didn't blow anymore but now the sockets have no power!.
When i arrived to have a look they said another electrician had come out and in order to fix the fault had replaced the consumer unit! The sockets still had no power to them.
Anyway i had a look and found the house to wired in rubber cable.Obviously the blasting had totally destroyed the conductors blowing apart the fault and now was sat there with no power.
I turned my attention to the consumer that the 'electrician'(and i use the term loosely) had fitted.
Heres what i found.
http://i.Upload the image directly to the thread.com/OVG1tOt.jpg
He has used the old cotton covered tails and fed it through an unbushed hole with the red clearly digging into the consumer unit.
Also the main earth cable looked like it was only 2.5mm!
http://i.Upload the image directly to the thread.com/ADKv2od.jpg
No earth bonding to gas or water.
Heres the inside.
http://i.Upload the image directly to the thread.com/ooOlYg2.jpg
Needless to say there was no certificate,no labels,no part 'p' notification etc.
I am gob smacked at the incompetence of this so called electrician.
What do others think?
Yes mate a proper metal mitre box, especially made for cutting angles on trunking with a junior hacksaw.
My trunking / tubing cutter just makes straight cuts. I had one with an anvil bed where you change the jaws & could cut angles, but couldn't get on with it.
Heres what i found.
Heres the inside.
Fooking discusting!!!!!!!!!!!! He should be found and wired up to the scrot, and at least 50 amps or 415 volts!!!!!!!!! He should be sorted out because that could be someones life.
Blackpool,Lancashire.
Cowboy electrician
Bob Geldoff1234,
Pete999,
