Customer wiring own electrics | Page 4 | on ElectriciansForums
Discuss Customer wiring own electrics in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Nottingham
Hey guys
Went to a customer today who wanted some electrical work looking at. Turned up and he showed me a granny annexe he had wired himself. (He has assured me he has 30years experience in the industry) he now wants it testing and certifying and a part p certificate issuing. I’m not comfortable with putting my name to the install and doing an electrical installation certificate. What would you do in this situation and what are his options.
I'm an electrician with 20+yrs experience, but I'm not in a scheme as I don't do domestic work. I re-wired my own house as part of a total refurbishment and simply sent in the certificates to BC paid the money and that's that.
If the OP's client has the relevant qualifications then it should be no problem for him to do the same. Maybe he would just like a second opinion to double check his own work !
Hey guys
Spoke to napit today and they advised to contact building control to see if they would accept an EICR and then he would have to sort part p himself. I spoke to them and they wouldn’t accept this, so I now have to do an EIC and get the customer to sign the design and construction part and just carry out the inspection and testing. The customer will then have to go through building control himself to get his part p. Spoke to the customer and told him the situation and his response was straight away ‘oh just leave it, I will sort it myself’. May have had a lucky escape there.
The customer will likely end up doing nothing....
Or after some digging will likely find a sparks to give him his part pee for same cash in hand
Either way it’s no longer your issue , which is probably a good ting
Hey guys
You can't sign for Inspection and Testing without having been involved with the job throughout. How could you possibly have inspected any concealed cables etc.?
There is a 3rd party certification scheme run by Napit and Stroma (I think).
From what I understand, you have to be registered with them to conduct 3rd party notifications, and the ‘certificate’ issued is some kind of EICR.
Stroma allow you to add 3rd party notification to your registration (it’s not automatic) and you have to be quite involved in the job from the start. Their website states the following:
Responsibilities of a Third Party Inspector
In order to carry out a third party inspection in a compliant manner, you must be in attendance to witness the work done at the 1st fix and 2nd fix stages of the installation. You must have witnessed the installation work and have confidence that it is both safe and installed to the required standard. You must then complete a Stroma Third Party Certificate and send this to Stroma Certification prior to making a third party notification.
Why is it not possible for the local authority building control to come and inspect his work, our LABC charge about £250 or if he has not already notified them that he has started £350 for a retrospective inspection. Might be worth asking your LABC if this is something they do.
How are the Napit/Stroma 3rd Party certifiers covered, if they’re only testing and notifying the work without seeing how it was installed? Do Napit/Stroma exempt their 3rd party notifier contractors from any prosecution etc?
If the customer has been doing their wiring. I would be respectful and decline, once you start wiring or changing anything you own it then. Good luck and some jobs you just have to walk away no money is worth your reputation
Reply to Customer wiring own electrics in the UK Electrical Forum area at ElectriciansForums.net
2 3
OLEV is now OZEV, in case you weren't aware. Installing EV equipment is not as straightforward as many might think. There is a Code of Practice...
loz2754
L
