has someone wired an immersion heater on the rfc? that will read about 20ohms.
Discuss Dead short between line and neutral- RFC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Is the insulation damp? Any outside lights, sockets etc. Are your batterys ok in your tester?
I unplugged everything and turned off what i could not unplug. There are some sockets that I cannot get to to pull the plug but can turn the sockets off. Would this still affect results?
L&N to E and you still get a poor reading, so either L or N is getting to E, or E is trying to be N or vice versa, have you carried out similar tests on the lighting circuits ?? earthing issue, thinking out loud here
Pict
Reply to Dead short between line and neutral- RFC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
