Do hand dryers require RCD protection | on ElectriciansForums
Discuss Do hand dryers require RCD protection in the Electrical Appliances Forum area at ElectriciansForums.net
C
C&H
Guys i'm doing an EICR at the minute. Do hand dryers for public use require RCD protection? Wired in singles in earthed steel pipe, no bath or shower in the room........
but on a EICR, the worst he can do is a code C3, or a comment recommending RCD protection.
If the hand dryer is hard wired on a TN system and as the cable is conduit run and is not in a room containing a bath or shower then the regulations do not require RCD protection of the accessory.
However probably a good idea anyway!.
Shouldnt be coded at all if it's not a requirement of 7671....this is why EICR's vary so much,electricians introduce personal opinions when the ONLY criterior is whether it complies onr not.
Agreed, I missed the earthed metallic pipe bit!, IF its in a bog not a bathroom, NO code could reasonably be given other then an observation.
Depends on the type of installation, I would avoid RCD protection on fixed equipment at all cost, however if TT for just one example then it would need it, whats the earthing arrangements and whats the zs reading?
Reply to Do hand dryers require RCD protection in the Electrical Appliances Forum area at ElectriciansForums.net
Duh!!! Just re-read Op's original post, it was converted to a RFC!
Usually if there are only C3 observations it would usually be deemed satisfactory but could be found to be unsatisfactory in unusual...
davesparks
