Do tails HAVE to be upgraded?
nope , its aimed at any type of installation with a supply no more than 100A.
Biff, on this occassion I need to disagree with you. Its references to previous versions of the regs/colours etc are limited to say the least hence my "mainly" comment.
page 11 , section 1.1 scope
" It (the OSG) covers the following installations ;
domestic and similar installations inc. garages , outbuildings
small industrial and commercial , single & 3 phase installations"
the guide is restricted to ;
a frequency of 50 hz
nominal volt 230 / 400
cut-out fuses rated at 100A or less"
no mention of new builds only.
and the knockout blow is delivered :-)
Has anyone actually asked the question "What size are the existing tails"? ? ? ? ? ? If it's on 4mm t&E then maybe the answer just could be YES!!!!! UPGRADE THE DAMN THINGS!!!!! lmfao!
No but I am sure the statement are the tail size adequate for fuse covers that.
Thanks for the responses.
The existing tails are 16mm and as its a one bed flat, there is a 6 way consumer unit consisting of a ring, lighting, cooker and shower circuit.
I would say the original 16mm tails are adequate.
Also, an isolator for the supply is being fitted by Eon next week, if that makes a difference?
Would like opinions after above details added please :)
So are you now asking for someone on here to work out diversity for you?
What's the supply fuse capacity?
No I'm not, I'm just making everyone aware that its not a big load like a mansion!!
Hmm, assumptions. A one bed flat with electric storage heating, and 10Kw shower, halogen downlights across the board and an electric oven and hob. As opposed to a seven bedroom property with gas heating, shower fed from the boiler, a single pendant in each room and a range or gas cooker.
Don't guess or make assumptions, use your eyes, experience and some basic calculations. The starting point is what do the DNO have protecting it? If it's a 100 amp fuse then your assertion that "it's just a one bed flat." won't be much use as a justification for leaving the tails.
Still no response on the fuse size?
Personally I frequently upgrade the tails to 25mm. I do so because the additional cost is negligible, I may not be able to verify the fuse size, it looks better afterwards, the old tails may be damaged/scruffy, the run is short etc. In other words, it's easier and quicker to do so. However, if the budget is tight for the customer and/or the tails are 16mm and in good shape then I check the figures and note down on the sheet that the tails are of adequate size for the installation.
What I don't do is guess or assume that they're OK.
It could be reasonably argued though that for a CU change only no load is being added....and if it's been running for the last 20 years on the existing tails without melting whats going to change?....that would be a reasonable assumption without any calculation.
Still waiting on reply regarding switch fuse/ryefield at cut out position.
