The blind leading the blind
I'm not blind, but maybe you could post the correct "maximum length" for metre tails. (After all, I only said I think the maximum is 3 metres as I was not sure.)
There is no maximum length in Bs 7671...but the DNO usually specify a maximum length without an isolator. This varies from 2.5m-5m....check with your DNO.
And it's got nothing to do with mechanical protection.
Isolator or switch fuse??
Depends on the installation and earthing method.
You will have to work out the necessary csa for earthing and bonding.
That could be because you actually use a lot more than you actually need.Those calculations always show a lot less than you would actually use.
A lot would agree with you but I don't follow your logic.Surely its acceptable to just upgrade main earth and bonding if 16mm tails are protected by 60a fuse
The reason for not wanting to replace the tails is that it will be a nightmare as the meter is in a communal hallway. Also the run is about 6 meters so will cost a fortune on cable.
But it's not you paying? I don't think cable of that length will cost a fortune, but how big is your fortune?
I'm afraid these are the type of jobs I walk away from then. If a customer doesn't want it done properly. Pay cheap, pay twice.The person I'm doing it for does not want to fork out money if its not required. Times are tough.
It will cost approx £50 just for the cable.
25mm tails are £3 a meter and I need 6 metres of each + 16mm earth.
