View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
What’s more amazing is the customer is adamant it’s not DIY. He had another electrician in who left the job half way through and hasn’t been back in touch. 🤔 I’m guessing he’s fell out with ‘Dave from the pub’. 😂
I’ve disconnected the lot. Initially he was a bit miffed I’d disconnected it all. But I said that’s what needed to be done as it’s not safe. Explained to him a few options of how it can be resolved and he’s asked for a quote and when I have availability.
That’s good that he’s been reasonable about you disconnecting it and wants you to do it properly. It looks a right dogs dinner in those photos.
Where's that what looks like swa in the meter cabinet come/goto
That’s the SWA for this abomination. It goes to the fused spur under the consumer unit you can see in one of the pics.
Not glanded anywhere, not that it matters as they’ve peeled the armour back to shove it into the box with the 3 core & earth PVC cable. 🙄
Ahhh I was wondering because it's following the dno cable I thought it may have been a bypass didn't realise it's looped through :)
Asked by a relative to change a light switch. OK no big deal, unscrew the two fixing screws as usual, pull them out...and out...hmm by time over 5cm of screw has exited I was not expecting great things:
Now they have identified black as (presumably) switched live but yes that really is polystyrene bulking up the wall with the back-box recessed by several cm. Chock block probably all that existed at the time (done at least 16 years ago) but also not visible is the bottom left corner where the earth tag screw was just spinning and no gip of the CPC at all.
Nothing like the sort of other crap that makes it here, but not my ideal job when not prepared to actually fix it properly. Best I could do at the time was to use on of the woodscrews to retain the CPCs.
Just use one of the upper or lower 3.5mm plate fixing screws.
Had I known the state I would have planned on a new backbox and maybe tried to space it forward so the normal (as supplied) screws would work. I just happened to have new 5cm ones (bizarrely enough, from another job a year ago where they turned out not to be needed so I left them in with small tools in car) so they did get clean screws as well as a new paint-free switch.
You can get extension collars for back boxes in various depths from any good electrical wholesaler, easier to fit than it is to try and remove a backbox without damaging the wall or just opening up a can of worms
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
