View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
On the theme of plumber. Couple of call outs on Monday.
First one was a tripping boiler. Plumber had the wisdom to put the wireless stat directly under the boiler, which leaked straight into the stat. They’ve also used the earth as a core.
Second one was from a plumber who was trying to wire in a switch for an immersion and also a shower pump. Couldn’t work out why every time they screwed the switch back it tripped.
I politely told them it was their rubbish wiring and they’ve nicked the live so it’s tripping on the back box.
I sorted it all out and tidied it all up.
At a friend's party last night, but seeing an extension lead plugged in to an extension lead, plugged in to a multi-way adaptor in the hall for the garden use and not and RCD in sight made me wince. Had a quick look as she was telling me of other electrical woes and its not pretty, though far from the worst to appear here. Sadly whoever did the last wiring could not be bothered to remove the old heating fuse box, not event to remove or cut the tails off!
The top butchers of the box is impressive, more care and effort than a hammer hole, but still such a mess. Of course why put in a blank when there is a live busbar within finger reach?
The supply is in pyro and I hope the red sleeve is just for identification as it looks af if the copper is exposed off the pot, but maybe there is black sleeving below? I decided not to poke it just to find out.
Its not a great installation and at some point I should try and help out. Blanking the spare and maybe RCBOs replacing the Proteus MCBs is an option to avoid the hassle of trying to redo the tails the correct (non seal faerie way) but I don't know if current Proteus RCBOs are compatible, and for all the cost a new metal CU of a brand I prefer might be less trouble in the long run.
Price to Rip that entire monstrosity out and start from scratch all new , or don't touch it at all
If this was commercial then 100% what you say.
As a friend I would be happy to donate my support but it probably comes to the same thing - the cost of a new CU is less than the time wasted trying to make something less crap out of what is there. The other thing slightly troubling me is this is a 40-60s build I guess, and it has asbestos panels in places, so I am not going to make changes that mean new holes being drilled. Thankfully there is plenty of 19mm (I think) plywood there to fix stuff to.
I also dread to think what else will need attended to. There is an unmarked 16A MCB which needs to be identified, also there appears to be two RFC for a two bedroom flat, so possibly one is for the kitchen. But it has damn-all sockets and so she has an extension lead to plug in dishwasher and washing machine in to a single socket under the sink. Yes, more WFT? and another burned out aspect to properly fix.
The other oddity is two 16A socket circuits for the attic conversion. It is a single big room with only around 6 sets of sockets! Wonder if it was done by EU folks?
Single light circuit is another thing, though I would not be too surprised if that unmarked 16A turned out to be attic lights. And there is an outside PIR flood-lamp that is playing up and she is unaware of any means to switch it off, or indeed what circuit it was taken off.
While trying to find out why a bathroom light doesn't work (for 3 months and multiple people have looked at it and ran away), it was obvious there was no power to switch...and the cable toner/tracer led me to this point as where it left the room. There was a suspicious severed cable the other side of the wall so I thought I'd have a look.
I decided to make the old feed safe and run a new one in the end. As there was no loft at all in this house it was time to break out the super-rods and today was my lucky day:.
And then some D-Line, sticks like, and filler (and some future sanding and painting....)
The exciting candlelit bathroom visits are no more.
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
