Guest viewing is limited
Darkwood
1 x 3A Smoke detector circuit (shows the age as it was a 3A 60898 which I haven't seen before)
It is uncommon to see anything below 6A in domesitc systems, but a few suppliers do ones below 6A but usually C/D curve.
What beggars belief is that someone thought it was a good idea to run those two sub mains from a 40A MCB in the first place! 🤦‍♂️
It probably did not start that way! Sadly it was clearly not a designed process of what and how things would be used :(
Having two sub-mains back to the main DB at least would allow better visibility of total loads if nothing else can be done.
Not technically our trade, but telecoms. This was a contractor on behalf of Openreach working on my street this morning.
They had this opened up behind my driveway, with barriers around and warning signs.
In the last half hour, they’ve gone, and left this open.
I just phone Openreach, and they say it will be sorted within 4 hours
4 hours!!!
4 hours!!!
thats bad to leave the foot way box open, must be rushing around like a lunatic, pair of side cutters handle in the slot drag it back down. lol
FGS man! Just put it back while muttering about the youth of today and how standards have slipped.
Ya moaning old bugger. :D
Hey... not my job. I might put my back out doing that.
I might put my own barrier around it... but why should I? If someone falls in... its on Openreach
Was thinking of "accidently" falling in myself, just for the compo 😁
I'm thinking this isn't very neighbourly.
If some kid or elderly person breaks their leg (or worse) Openreach might pay compensation, but you'll kick yourself for letting this remain open for hours.
If you don't want to move the cover, maybe park your van over it?
Or fill it with concrete. Be very safe then 😀
I personally would just drag the cover back on. Five minutes and all safe.
And then you get all the "who touched it last?" problems...
I don't have the proper tools for lifting it... Im not trained to lift it....
I don't even have cones myself that i could put out as a barrier...
I suppose i could put the rabbit run over the top of it..... Without the rabbits 🐰🐰
Dear me. Just do it, nobody will sue you!
8K
Darkwood,
vjsmarwick,
