View the thread, titled "Domestic DB" which is posted in Domestic Electrician Forum on Electricians Forums.
P
Phaze-3
Hi Guys,
Take a look at the picture below. (you may have to turn your head as i couldn't work out how to rotate it it).
As you can see, the DB has seen better days so i am going to replace it with a nice new one with plenty of ways.
I don't get to involved with domestic work as i really only work with industrial installations and bigger stuff. Few questions you guys hopefully will be able to help me with. I will just add that this is a TT System to this house.
1) How far does does the main intake and DB need to be away from the Gas Meter?(As you can see, it is pretty close)
2) I done a Ze on the existing board and was getting a silly reading! Do i need to be looking at installing a new earth rod? If so where is the best place to put it?
3) Choosing a new DB. I was thinking of getting the usual 2 x RCD split boards. Now do i need an RCD Main Switch to feed the Split board (if that makes sense). and if i do does that main switch ideally need to be 100ma?
or
4) can i put a normal DB in with a 100ma main switch and RCBO's to feed each circuit.
I've been a spark for 14years but only ever work on industrial installations and dont know that much about the domestic side of things these days. There are just a few little question im just not sure about when it comes to some of the regs that are involved in domestic installations.
Cheers Guys
Steve
Reply to the thread, titled "Domestic DB" which is posted in Domestic Electrician Forum on Electricians Forums.
