domestic lighting and consumer unit | on ElectriciansForums
Discuss domestic lighting and consumer unit in the Domestic Electrician Forum area at ElectriciansForums.net
worcestershire
Sorry new here, just had an electrician pop round to quote for work, domestic home electrics, uk, worcestershire, when he saw that my downstairs lighting was wired in a ring (ie consumer unit has 2 lives to the RCBO, away and return - sorry not sure on the best terminology) he was unhappy as he would have expected it to be a spur, should i be worried about it?
A ring would be unusual for domestic lighting, however, even if it is a ring it would not fall foul of any regulation I can think of.
Assuming that they just took the lid off, looked at the wires and said "this is a ring and it is wrong so i won't touch it"
It is probably not a ring, the only way to be sure is to test it.
I would recommend finding a different electrician.
Thank you, that was my feeling spent all day feeling like i should be wearing short trousers and asking for a packed lunch.
He also had a problem with there being 3 wires in a downstairs ring main RCBO these were the downstairs ring (2 live wires) and a single additional socket on a spur powering the BT router right next door to the consumer unit, can't say i am a fan of the mechanical aspects of electrical connectors (as a mechanical engineer) but i am puzzled about this being a problem
again, i would doubt his experience and knowledge.
A spur from a ring may be taken from any point of the ring (socket, fused connection point, junction box) or indeed the origin (circuit breaker)
appendix 15 in the blue book (p.s. i know it is not the latest edition but it is what is at hand right now!!)
Thank you, looks like going back to getting 3 quotes might be the best way
i dont know how anyone with any experience looks at 2 cables at the rcbo and instantly assumes its a ring....
Sometimes it is the easiest place to branch off to feed a single outside light... or doorbell transformer... or anything!
Makes me wonder what they're being taught these days
Reply to domestic lighting and consumer unit in the Domestic Electrician Forum area at ElectriciansForums.net
2 3
