Downlighters Earth Question | Page 3 | on ElectriciansForums
Discuss Downlighters Earth Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As suggested, I use clicks
You must take an earth to the light and just over sleave it or into a terminal block, this is so in the future if class 1 used the earth is there.
Supplier is assuming loop in at d/l which is why they say 1.0mm2, therefor 0.75 flex is fine, you are only running 1 d/l per flex.
So to sumarise,
10a MCB
earth to every D/L, terminate in conector
1.5mm2 t+E to a click connector for every D/L
0.75 3core flex from click conector to each D/L
A 10A mcb seems a little excessive for this lighting circut. KLIX are a good thought, but you still have the problem of where the cpc is terminated in the fitting - or ecen if it is on a connector block, is there space inside the enclosure of the fitting ?
You would get away with a two core from JB to light fitting - as long as it isn't to long, but more importantly, the JB pops out the ceiling as easily as the light fitting so you can access all connections.
Realise this is off the original question but could some one answer if ur testing a light circuit and they happen to be all GU10 type lights wat sort of test r u meant to do as the actual fitting wont hav an earth unless fitting has metal holder????is it just meant to have a n IR test?
Take the readings at the termination where the earth is.
Take the 1 or 2 ends of this (depending if its loop in loop out)
[ElectriciansForums.net] Downlighters Earth Question
then connect them into some of these
which I ususally house in one of these
then from your Wago connectors take a short length of this
and terminate it to the downlighter, sometimes, dependant of the downlighter, I may use some of these
:D
Reply to Downlighters Earth Question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
