downlighters on ground floor! | Page 6 | on ElectriciansForums
Discuss downlighters on ground floor! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have been asked to fit downlighters to a hallway and also a kitchen all on the ground floor.
The customer would prefer me not to take up the carpet and floor boards above, but I cant see anyway around this? I might be lucky with the hallway and have them all in a straight line running the same way as the joists and manage it with cable rods but the kitchen will have the lights all over the place.
Is there anyway of doing this without taking up the floorboards?
Cheers all...
If the light is not pulling up against the ceiling it could one or both of two things...
Spring is hitting a joist close by
or, the spring is being held of off the back of the plaster board by some debris etc...
However, sometimes it can be cheapo fittings.
or sometimes the cables are up against an obstruction and push down on the fitting. seen this mainly when some idle bugger has taken T/Es into the fitting, instead of switching to flex (i use line enclosures, but click connectors or various types of JB are also acceptable)
[ElectriciansForums.net] downlighters on ground floor!
Reply to downlighters on ground floor! in the UK Electrical Forum area at ElectriciansForums.net
Floor tiling 600x600 48m2 Hello, this is my first post here, but I have been doing some reading. I am going to be tiling the whole ground floor...
Spacebug
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
