downlighters on ground floor! | Page 5 | on ElectriciansForums
Discuss downlighters on ground floor! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have been asked to fit downlighters to a hallway and also a kitchen all on the ground floor.
The customer would prefer me not to take up the carpet and floor boards above, but I cant see anyway around this? I might be lucky with the hallway and have them all in a straight line running the same way as the joists and manage it with cable rods but the kitchen will have the lights all over the place.
Is there anyway of doing this without taking up the floorboards?
Cheers all...
They look perfect Telectrix, Thanks.
had a quick scan on ebay and screwfix but cant find them? Where do you get them from and what are they called?
I picked up a load from B& Q,They are called Safeplates, i found them in a dusty old box next to joist hangers etc, they do them in a few sizes. I find them very handy, even our gas safe bloke uses them now.
Nonsense
Ive done hundreds of downlighter jobs without lifting floors OR having to get the ceiling reboarded. Theres more than one way to skin a cat. I normally give the client the option but Im perfectly happy to do it from below.
Didn't say its impossible was referring to OP's instant where customer seems to be calling the shots without appreciating what might be the most economical and easiest way, ive had plenty of similar customers and just giving them the various options against each other is usually enough to persuade them IF it will be beneficial to do it from above. Of course if your going with the joist run, with a plasterboard ceiling its no hassle to fit a row in a corridor and each situe to its own. Was never saying its impossible and if the customer is willing to pay for the extra then so be it, it just seems overkill because they don't want a carpet lifting.
And you've never seen 6 downlights so beautifully aligned!
Like this?
[ElectriciansForums.net] downlighters on ground floor!
It's a job I helped my mate on. The bloke who lives there was determined to have twenty downlights in that room! Obviously the centre row fell right on a joist! My mate was determined to drill the joist out but having fire rated lights it wouldn't have done the structure any good! Plus when he initially marked them out they were ****ed as anything! In the end we got him down to sixteen lights and rid of the centre row! I'm sure my mate was ****ed up though!
Well if the pics anything to go by and your mate hitting the centre joist then hope you have the required joist clearance on the other fittings ..... I wouldn't be working with anyone who thought it was ok to drill a joist out and stick a gu10 in .... I've seen the effects of such dumb practices myself.
As said we managed to get rid of the centre row of lights so we didn't end up drilling the joist. Good thing is the builder agreed to re-boarding and plastering the whole ceiling again instead of just patching up.
gu10's are awfull.
horrible light output, lamps blow everyday ! etc...
low voltage is best.. if you must have halogen
retro fit LED lamps are generally rubbish and they don't dim well
i dont fit either anymore
the price of aurora's / halers LED fittings are now so cheap, it doesn't warrant fitting non led fittings anymore
- - - Updated - - -
might as well had ripped it down then.
still a bodge job under the floor :) lol
looks a bit hit and miss, if buider had agreed to re-board and plaster i would have dropped the ceiling , looks like plenty of room to do it, and safer i think than drilling into a ceiling when you don't know whats up there. Or drill series of pilot holes (drillbit not holesaw ) find joists, ping lines (chalkline ) , mark out light locations (between joists) , drill pilot holes (just to check). If all is well , cut holes and pray the last trade to lift upstairs boards didnt sweep all their debris in there or plumber/electrician didn't lay pipes etc on top of boards you are about to cut holes in ( i think we have all seen it ). Last job i did , dropped ceiling , left 300mm gap round edge , put in 20 led downlighters, stuck colour changing strip around perimeter, effect was good. room to run cables safely and easily. If i can't see what is up there i will not entertain job, not worth the worry.
All fitted.... and in a record time of 5 hrs! :redface: 2 jump joists which I managed to reach by taking up lino and floorboards in bathroom rather than making lots of holes in the ceiling. Wago fitted neatly (used them for the first time, I like them).
The only thing that was a bit annoying was one of the lights didn't fit snuggly against the ceiling when pushed up as the springs didn't seem that strong. If I had access from above this would be easy to remedy.
Does anyone else find that the springs dont always hold the lights up with a nice tight fit against the ceiling?
Reply to downlighters on ground floor! in the UK Electrical Forum area at ElectriciansForums.net
Floor tiling 600x600 48m2 Hello, this is my first post here, but I have been doing some reading. I am going to be tiling the whole ground floor...
Spacebug
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
