Downlights | on ElectriciansForums
Discuss Downlights in the Australia area at ElectriciansForums.net
M
MAD SPARK
Just installed some mains voltage Downlights. They all work ok but after half an hour i get a burning smell appear in the loft. Its just like burning dust. There is no insulation up there and the ceiling is brand new. What the hell could it be. All the lights are connected with flex. The flex goes to a joint box. I then have 1.5T&E between each joint.
these are the downlights used
Fire Range - TD-661 - Starlite
i dont like gu10 lamps...nowt but trouble..gimme a transformer and 12v lamp anyday!!
i went to a job recently cos a customer said his lights wernt working and he said he has had problems with squirrels...
an understatment..the little bugger had eaten virtually everything...the live and LV sides of the transformers were gone and the 1.5's were dessert!!.
though the burning smell there wasn't dust...it was barbequed squirrel.
Reply to Downlights in the Australia area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
