if it's speed you're concerned about, use the round dry lining boxes. much quicker to cut out with a hole saw.
Discuss Dry lining boxes substitute in the Electrical Tools and Products area at ElectriciansForums.net
I can cut a dry line box in, in nder 1 min including putting the box in with wires, this using a draper box cutting template without the spring. Nice and easy, don't see why you would want to do it faster.
It,s a damn rough way of doing it,may as well have no box at all,definitely a non compliance in my opinion,as all connection a should be made in a non flammable enclosure.I've never seen any need to use anything else. I prefer to use galvanised boxes where possible, otherwise fastfix boxes are available just in case. I find both are as adaptable as I need them to be.
On the job I'm on at the moment the accessories are extra deep so we've been cutting away most of the back of the box and wrapping grommet strip edging around it so the accessory pokes into the void behind, then the boxes have been fixed into the panel using screws through the inside edge of the box. Not ideal IMO but it's one way of doing it.
Generally - Studwork I use drylining boxes...metal KO boxes screwed to noggins tbh seems labour intensive when there is no real need for it. Finish is neater and takes less time.
Each to their own, but personally....adding noggins/dwangs to studwork just seems to wasting time / doing things the same way just for traditions sake...when a better solution (in almost every case) exists in form of fast fix boxes/drylining boxes.
Reply to Dry lining boxes substitute in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
